[ View Full Version Of This Page ]
1995 camry strut removal
All Forums » Suspension, Brakes, Tires & Wheels » 1995 camry strut removal
cali_g
2/4/2007 1:55:18 AM
Has anyone in here removed the rear struts??? its a 4 door sedan, i just got some GR2 for it and i can't seem to be able to remove those arm rest next to the rear seats any tips??? i thought they were held by clips, but i'm begining to doubt it. thanx ahead for any suggestions.
unsub
2/7/2007 8:14:05 AM
I did all the struts a few months ago on my 93 sedan. If I remember correctly, there is a bolt on the bottom which you can get to by lifting up the bottom corner. There is a hook up higher that disconnects by lifting up on the cushon after you remove the bottom bolt. I learned the hard way by busting off the first hook. Then on the second side, the bolt at the bottom broke off. You may want to soak it with some penetrating oil first. If you haven't flipped the seat bottom up yet, that will also help.
nodrogkam
2/7/2007 10:20:53 AM
http://www.turboninjas.com/camry/
one of those manuals will probably help you out.
www.toyotanation.com is another forum you may want to join.
wantahertzdonut
2/8/2007 3:30:47 PM
Just like unsub said, there is a large bolt (17mm I believe) at the bottom that holds the armrest in place.  And be careful of the hook!  A Haynes manual has a nice picture of the whole thing if you need a good visual reference, which you should have anyway if you're replacing your struts.
Don't forget to get an alignment when you're done, you will need it.
Return to the Camry Forums home page - Archive Home
