[ View Full Version Of This Page ]
2005 power door locks
All Forums » ECU & Electronics » 2005 power door locks
ambarr@pcbc.org
6/12/2008 8:23:01 AM
Drivers door unlocks every time using both keyless remote and door key, all other doors will not unlock electronically. However, all doors will lock using keyless remote, door key, and when the car is placed in gear. The problem used to be intermittant, now works properly only about 1 out of 100 times. Drivers door unlock switch only unlocks drivers door, all other doors are unaffected.
toyomoho
6/17/2008 6:33:06 PM
Typically would state to check the wiring between the drivers door and chassis as over time they can become damaged due to door usage.  However these newer locking systems can be programmed, perhaps it needs reprogramming.
wecan
7/7/2008 2:57:03 PM
http://www.onvon.com/car-dvd-player-c-29.html?skey=w03
mabye through this website you could find out what you like really
hope someone would be visit it and then give me some advice
with great thanks thank that if there would be have some people to visit it
thanks in advance
hieply
7/21/2008 10:43:00 PM
I have the same identical issue with my 2005 camry LE.  Were you able to fix the issue with your camry locks?
Related Threads
Return to the Camry Forums home page - Archive Home
