1998 toyota camry
1998 toyota camry
electric window drivers side. Goes all the way to the top and pushes out and goes out of the track and crushes the rubber. I have tried to bend the rubber out to make the window go up and seal tight and it wont. What parts should I replace to get a good seal and is there an adjustment I need to make. It seems to go up perfect the just not seat perfect in the rubber around the window. Is that track rubber expensive? thanks tom
RE: 1998 toyota camry
I have the same annoying problem. The part is called a window run and is about 90 dollars from the dealer. This is what i found in my research. If you find anythign different be sure to let me know.
I took the whold door panel apart. Could not find any adjustments to be made. Guess I have to go to a glass shop or something for this. The first camr that has kicked my butt. I cant even find the alarm box n this car. Now I cant fix the window.....
SMHS
07-11-2010 07:46 PM
camry.toyota1998
11-11-2009 06:31 PM
