need help taking out brake light assembly..
Old 07-21-2011, 12:25 AM
sonofnate10's Avatar
Default need help taking out brake light assembly..
hi guys need helphow to remove the brake light assembly on 2010 camry se v6 i want to put tint on my brake light but i cant get em off.. if somebody who can teach me or post a link that'll be great thanks..
Old 08-03-2011, 11:23 AM
Might ask at the Toyotanation website.
Typically the rear light assy has threaded studs that install through chassis holes and held on with nuts. Pull back the inner trunk liner or remove the lamp trunk liner access cover and look.
There may also be a plastic clip molded to the assy that comes through the side of the chassis. You may see the clip extending through the chassis from inside the trunk.
Once the nuts are off the assy may require gentle manipulation to remove it as the studs and clip can hold the assy snuggle in place. Don't force it.
Old 08-24-2011, 09:39 PM
full house's Avatar
wayney
05-15-2015 09:08 AM
DIYGIRLY
02-13-2013 09:27 AM
sonofnate10
07-21-2011 07:15 PM
red73mustang
03-23-2007 08:05 PM
red73mustang
03-23-2007 08:04 PM
Quick Reply: need help taking out brake light assembly..
