2010 Camry Hybrid w/NAV JBL amp replacement advice - Camry Forums - Toyota Camry Forum
Thread Tools Search this Thread
Old 09-18-2016, 03:31 PM
Default 2010 Camry Hybrid w/NAV JBL amp replacement advice
The sound for the radio, cd, etc. started getting scratchy and then cut out. For a while it would come back on occasionally for short periods, but no longer. As per many other posts about similar scenarios, the volume control doesn't show a change on the display now. The NAV works, including the turn-by-turn voice, as does the phone via bluetooth. I checked the 25A "AMP" fuse and its fine. And I checked the speakers in the trunk and there are no obvious shorts or anything touching the wires or speakers. All indications from what I read online is that it is the JBL amp under the seat.
I pulled it out and opened it up but didn't see any obviously burned chips (but I didn't diagnose further). I also went into diagnostic mode on the NAV and the "DSP-AMP" displayed "OK".
I'm about to buy a used amp on ebay but thought I'd check this forum first if case anyone has any additional advice.
Two questions:
1. Could the amp be dead and still not cause an error code in the system diagnostics?
2. The part number on my amp was 86280-0W391. Most online parts suppliers indicate 0W390 is equivalent (and most of the used ones on ebay are that model). Can anyone confirm that the 0W390 will work in a 2010?
Old 09-18-2016, 05:52 PM
It appears even a Toyota dealer has difficultly diagnosing this problem. Something about a short in the amp.
The 0W391 replaced the 0W390. What the differences are don't know. All sites state both are compatible for 07-11 Camry.
Best bet is before you buy to send a note via ebay to the seller asking if the 0W390 can be used for a 0W390 for this year of car. If problems can then send it back and get a refund.
Old 09-24-2016, 11:20 AM
UPDATE: I Bought a used amp on ebay for $193 from partsconnectionnj. It arrived in about 4 days and was marked as coming from a 2008 Camry and was a 86280-0W390. I put it in this morning in about 30 minutes and the radio is working again.
This is a very easy repair that, contrary to Toyota's repair manual, can be done w/o removing the passenger seat. With the seat full forward there is ample room to remove and replace the amp. The hardest part was getting the plastic clips out to remove the cover. If you don't have a clip removal tool, you can use a screw driver to pry them up a little then use a needle-nose plier to get under each one and work it out. Then remove the bolt holding the ground wire and the bolt holding the amp to floor. Squeeze the middle of each of the three wire connectors and pull out. The wire harness is taped to a plastic strain-relief pin on the front bracket, which is a little hard to reach under the seat. It might be possible to pull the tape off, but I found it easier to break the strand of tape attached to the plastic.
The replacement came w/o the front and rear brackets which are held on with star-head screws (so you will need a set of star bits). It took about 5 minutes to remove the three screws from each bracket and reinstall them on the replacement amp. At this time I used a needle nose pliers to remove the strain relief part from the front bracket (once you have the amp out this instruction will be obvious). I did this to make it easier to rewrap the tape around it later.
Reinstalling took 5 minutes. First I reached under the seat, unwrapped a bit of the tape from the wire harness, and wrapped it back around the strain relief pin. Then I put the amp back in position, plugged in the three connectors, put the ground wire bolt back, and put the bolt back into the floor. I then turned on the radio and verified it worked again.
I moved the seat all the way back and from the front pushed the plastic strain relief part back into the front amp bracket. (Note: I'm sure it would be fine to ignore this tape and bracket connection and nothing bad will likely ever happen.) Then I moved the seat all the way forward again and put the plastic cover and pins back over the amp.
I saved at least a $1000 doing this myself (plus the inconvenience of leaving the car at Toyota). Even if this amp dies in a few years, I'd do it again and still save time and money.
I hope this info helps others interesting in doing this repair themselves.
Old 09-26-2016, 02:40 PM
Great job and DIY post!
Thanks for posting.
Thread Thread Starter Forum Replies Last Post
Add sat nav to 2014 Camry Hybrid pikov Audio/Visual Electronics 3 08-26-2016 01:50 PM
Toyota Camry Hybrid 2010 All Cells good but still shows 'check hybrid system' light mafzal General Tech 1 09-10-2015 11:11 PM
2008 Camry - Advice on replacing JBL system consequential Audio/Visual Electronics 4 09-03-2015 05:24 PM
Anyone upgrade a 2011 hybrid w/JBL to a factory JBL nav? lonewolf41 Audio/Visual Electronics 7 05-10-2014 12:36 AM
2005 Camry Backup Camera for JBL Nav novaman83 ECU & Electronics 3 08-21-2011 10:55 AM
Tags
amplifier, audio system
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
