Installing Ground-Loop Isolator into 2007 Camry
Hello,
My name is Martin, new to this forum. I am trying to install a Ground-Loop Isolator to my factory stereo/cd that came with my 2007 Camry CE.
I have an external GPS with bluetooth (for hands free cell) and MP3 playback. I have been connecting it into the Aux input. All works well until battery runs low and I need to plug in the power 12v adapter. IT then creates an annoying humming sound that according to Tom Tom forums can only be removed by adding a Ground-Loop Isolator.
The OME stereo does not have RCA inputs. The back side of the Aux input has a 4-pin plug (green-green-brown-red). I have no idea how to connect this isolator.
Any help would be appreciated.
Martin
Martin
The isolator is plugged between the aux input of the radio and the device you are using.
Isolators due come with different plugs then RCA type, see link below and PNI-135 Mini-Jack unit:
http://www.bizrate.com/caraccessorie...ator+cars.html
I found the solution to my problem. For anyone interested see the link below:
http://www.technogab.com/images/main/TSB-0067-08.pdf
Martin
Martin
If you want to go with Toyota fix try the Toyota dealer at the link below. Mail order parts at 15% over dealer cost, great service to!
http://www.1sttoyotaparts.com/
Condensor is the same name for capacitor. This is a differant device then a ground loop isolator.
The condensor is sized to bleed off the electrical signals that are making the noise to ground. The other device isolates one circuit from another via a transformer and eliminates any issues with grounding.
Condensors are already used on the car to dampen out electrical signals from the alternator and ign system.
rockoalol
01-07-2015 07:07 PM
slakhani0188
07-23-2012 08:36 PM
obaid_chemical
11-02-2010 01:21 PM
Trojan
05-10-2008 10:58 AM
