Kenwood DNX570HD in '04 LE
I replaced the OEM CD/Cassette/Radio in my wifey's '04 LE with a Kenwood DNX570HD using the Metra Dash Kit #99-8231 and Harness Adapter #70-1761 . The screws that came with the DNX were too short for my liking (only one thread of engagement) to work with the dash kit. So I went to the local ACE hardware store and found M5x8 screws.
https://www.flickr.com/photos/145764...7644472872501/
Last edited by GringoZX; 05-02-2014 at 07:38 PM. Reason: Added link to photo album.
We're happy with it so far. I don't drive the Camry very often, so I haven't much of a chance to use the Kenwood. Wifey isn't very tech savvy, so she doesn't use many of the bells and whistles.
The only "cons" I have with the unit so far is:
1) I would like if they made the "Home" page more customizable by only having the icons that we usually use. ie Allow me to remove SiriusXM, iPod, aha, Pandora from the menu.
2)The Installation and Navigation manuals are not very clear on some of the setup stuff. Took me 45 minutes to figure out how to reselect myMaps in the Nav Settings after I updated the firmware. Seems that some of the settings are only available at power up.
3)Dimmer interface could be better.
4) The gps antenna cable should be ~25 feet and not ~15 feet so that it could be mounted on the rear deck of a mid/large-size sedan. Luckily, I was able to run the wire down thru the plug for hole in the dash where the DayTime sensor would have been if this car was equipped.
I've owned several Garmin gps units over the past 12 years and am very comfortable/familiar with using them. However the newest one (not counting the Kenwood H/U) is 4+ years old. And it took a bit to get accustomed to the User Interface of the Garmin Nav UI on the Kenwood.
ejm19
07-04-2009 09:51 PM
hungdang80
08-28-2007 05:01 PM
