need 2009 Camry factory radio wiring diagram
Old 07-03-2009, 12:34 PM
y2kwht150's Avatar
Default need 2009 Camry factory radio wiring diagram
Per title, I am in need of 2009 Camry OEM radio wiring diagram, any help would be much appreicated.
Old 07-03-2009, 10:25 PM
y2kwht150's Avatar
Hello, anyone??????
Old 07-26-2009, 02:03 PM
minilowz's Avatar
If its the same as the 08's
2008 TOYOTA CAMRY 4DR SEDAN WITH 2.4L ENGINE AND JBL® 8-SPEAKER AUDIO SYSTEM
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery BLUE & BLUE YELLOW (+) RADIO HARNESS
Accesory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Power Antenna ORANGE (+) RADIO HARNESS
Amp Turn On
THE AMPLIFIER TURNS ON WITH THE ACCESSORY POWER IN THE VEHICLE
LF Speaker (+) BLACK
THESE WIRES PROVIDE THE AUDIO INPUT TO THE AMPLIFIER
LF Speaker (-) WHITE
RF Speaker (+) RED
RF Speaker (-) GREEN
Amp Location UNDER THE FRONT RIGHT SEAT
Steering Cntrls YES
Speed Cntrl YES
Radio Security YES
Security
Battery BLACK (+) IGNITION SWITCH HARNESS
Ignition 1 YELLOW (+) IGNITION SWITCH HARNESS
Starter 1 BLUE (+) IGNITION SWITCH HARNESS
All Door Trigger BROWN (-) AT VEHICLE FUSEBOX
Domelight Super BROWN (-) AT VEHICLE FUSEBOX
LF Latch BLUE (-) AT BECU MODULE IN VEHICLE FUSEBOX
RF Latch YELLOW (-) AT BECU MODULE IN VEHICLE FUSEBOX
LR Latch LIGHT GREEN (-) AT VEHICLE FUSE BOX
RR Latch GRAY (-) AT BECU MODULE IN VEHICLE FUSEBOX
Trunk Trigger WHITE (-) AT BECU MODULE IN VEHICLE FUSEBOX
Hood Trigger RED (-) AT VEHICLE HOOD PIN SWITCH
Alarm Disarm BLUE (-) INGITION SWITCH HARNESS
Parking Lights BLACK (-) AT BECU MODULE IN VEHICLE FUSEBOX
Convenience
Headlights-Lo PINK (-) AT BECU MODULE IN VEHICLE FUSEBOX
All Hazrd Lights WHITE (-) AT VEHICLE HAZARD SWITCH
Wipers-Lo PINK (+) AT WIPER CONTROL SWITCH
Wipers-Hi GREEN (+) AT WIPER CONTROL SWITCH
Parking Brake YELLOW (-) AT PARKING BRAKE SWITCH
MAY ALSO BE BLUE ON SOME MODELS
Trnk Release BLACK (REV) AT BECU MODULE IN VEHICLE FUSEBOX
Remote Start
Ignition 2 PINK (+) IGNITION SWITCH HARNESS
Accessory 1 WHITE (+) IGNITION SWITCH HARNESS
Starter 2 GRAY (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense BLUE (-) IGNITION SWITCH HARNESS
THIS WIRE WILL DISARM THE FACTORY SECURITY WITHOUT UNLOCKING THE DOORS
Tachometer BLACK (AC) AT DATALINK CONNECTOR UNDER DRIVER DASH
Speed Sense VIOLET (AC) RADIO HARNESS
ALSO AT AMPLIFER UNDER PASSENGER SEAT
Brake Lights WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED (+) IN HARNESS IN DRIVER KICKPANEL
Horn WHITE (-) AT VEHICLE FUSE BOX
Modules
WIRE LOCATION
Please select another category
Doorlocks/Windows
Power Unlock GRAY (-) IN HARNESS IN DRIVERS KICKPANEL
USE A DOUBLE PULSE TO UNLOCK ALL DOORS
PowerLock BROWN (-) IN HARNESS IN DRIVERS KICKPANEL
LF Window Up GREEN (REV) AT DRIVER WINDOW SWITCH
LF Window Dn BROWN (REV) AT DRIVER WINDOW SWITCH
RF Window Up WHITE (REV) IN HARNESS IN DRIVER KICKPANEL
RF Window Dn RED (REV) IN HARNESS IN DRIVER KICKPANEL
LR Window Up BLUE (REV) IN HARNESS IN DRIVER KICKPANEL
LR Window Dn BLACK (REV) IN HARNESS IN DRIVER KICKPANEL
RR Window Up YELLOW (REV) IN HARNESS IN DRIVER KICKPANEL
RR Window Dn LIGHT GREEN (REV) IN HARNESS IN DRIVER KICKPANEL
Sunroof Open BROWN (-) AT SUNROOF CONTROL SWITCH
Sunroof Close BLUE (-) AT SUNROOF CONTROL SWITCH
davyvan
11-12-2010 09:44 AM
soccman
06-07-2010 10:54 PM
skidrowcustoms
07-28-2009 11:37 AM
bbaker
06-26-2009 12:26 AM
matt
11-04-2007 01:57 AM
Quick Reply: need 2009 Camry factory radio wiring diagram
