now for speakers
#12
RE: now for speakers
94 and 95 models, the rear deck speakers are bolted down with 10mm headed bolts. Flip the seat forward, remove the two plastic caps on the screws holding down the rear deck cover, remove the screws.
Being extremely careful, remove the cover of the rear brake light if fitted, removing the screws as soon as you get the cover up far enough to do so.
Then carefully lift the rear deck cover. You will need to carefully bend the edges to come past the plastic panels and the top of the seat sides.
Then proceed to remove the 3 x 10mm bolts on each speaker, replacing the speakers at the time.
It should take at least 1hr 30 mins to do this.
Dave
Dave
