Old 08-27-2015, 11:15 AM
How-Tos on this Topic
Browse all: Lighting
Print Wikipost
Wife hit deer. Front Driverside blinker not working and rear blinking quickly
Old 10-07-2010, 10:39 AM
tt837's Avatar
Default Wife hit deer. Front Driverside blinker not working and rear blinking quickly
2009 Camry
Slight indent next to driver side headlight, not bad.
Headlights work.
Front driver side blinker not working.
Rear driver side blinking quickly.
Where should I begin to self diagnose? Any thoughts are greatly appreciated.
Thanks
Old 10-07-2010, 01:40 PM
The blinker/hazard light system has its own wiring/system not connected to the headlights.
Have you checked the non-working blinkers wiring and bulb?
The front and rear passenger side turn signals are wired together (same for the other side).
If the front signal is not working, has a problem with the wiring, etc it might cause a load imbalance on the blinker flasher unit. The result is the working blinker will flash at a higher rate or slower rate.
Suggest you check out the front blinker for shorts, damaged wiring, etc. As stated previously the front and back bulb wiring is connected. If the back works, power is getting to the system. It may not be getting to the front bulb.
The owners manual should have info on changing the blinker bulb. If you have a volt meter you can check for voltage at the socket with the blinker on.
Old 10-07-2010, 02:11 PM
tt837's Avatar
I haven't taken anything apart just yet. I figured I'd better get a game plan together before I go taking apart her car. I just bought new bulbs for the front and back directionals just in case while I have apart. I need to find owner's manual to see where fuses are and how wiring is setup. Thanks for your help Joey P
TT
mpossoff
01-15-2013 07:11 AM
pe3wee
11-16-2012 03:14 AM
StormyWaters
05-09-2012 07:06 PM
Cronx210
09-17-2009 02:41 PM
arshop
12-08-2007 06:23 AM
Quick Reply: Wife hit deer. Front Driverside blinker not working and rear blinking quickly
