How do I treat dried out leather?
I have a 2011 Toyota Camry which I bought in 2013. When I purchased it, the leather had been neglected and was drying out and the problem is only getting worse. I haven't known what to do to fix the problem, and I'm finally getting around to posting about this.
The leather seems to have developed "scales" that are flaking off. The problem appears on the driver's headrest as well as the top of the driver's seat.
Here are my questions:
1.What step(s) should I take to fix this?
2. What product(s) should I use?
Thanks in advance,
Jonathan
Headrest Closeup:
Headrest 2:
Top of Seat (Hard to see):
Thanks in advance,
Jonathan
Headrest Closeup:
Headrest 2:
The issue may be the cars interior getting too hot from being parked in the sun and drying out. Leather is like skin and needs to have moisture or it will flake. To maintain leather interior, some owners weekly wipe a damp cloth over it.
Leather repair can be complicated because of how it was treated and dyed.
Is the car still under warranty?
Leatherique gets good reviews
Griots Leather Rejuvenator
Spinneybeck Leather Maintenance Kit
I've ordered some Leatherique, so hopefully that will help. If not, I'll check out the other products. Thanks again.
Jonathan
Might read the owners manual on any upkeep on these types of seats.
Were the seats in this condition when you purchased the car?
If no upkeep is listed and seats were OK upon purchase might talk to dealer about replacing under warranty.
I'll probably give some leather conditioner a try so that I can say I did that, but if that doesn't do anything, I will take your suggestion and complain to the dealer. Thanks!
I've had very good results with Neatsfoot Oil on dried out, stiff leather. Apply it liberally, and let it sit if you can for a day or even 2. Then wipe off anything that doesn't soak in. You can repeat this several times. It's not a quick fix, but if the leather is really dried out, this will help enrich it back to a soft condition. In between use a good leather conditioner. In high heat, low humidity leather can dry out quickly. Then it doesn't take long for it to start cracking and flaking. On some leather it can darken it, so try it on an area that isn't too noticeable to see if it changes the color of the leather.
marcusverkler
06-09-2013 02:34 PM
keithnetic
01-12-2007 03:23 PM
