touch up chips - Camry Forums - Toyota Camry Forum
LinkBack Thread Tools Search this Thread
Old 02-18-2014, 10:20 PM
Smile touch up chips
started touching up my new 2012 white camry, has 2 chips I'm addressing & they are blackish looking. Is this beneath the primer? Manuel says may need to prime. Wondering what color is the primer? COULD this black be rust proofing?
Old 02-19-2014, 01:36 AM
Where are these chips located? Is it on plastic or metal pieces?
Old 02-19-2014, 10:12 AM
they are on metal, the plastic back bumper also has black cuts from backing into stuff.
Old 02-20-2014, 01:58 AM
If you are not seeing metal then you can just use touch up paint. I suggest going to your local Toyota dealer for the touch up paint so it is factory match. Just know that you will notice the touch up in the finish because it will be hard to get the surfaces to match up again. A body shop would sand down the area, prime, sand, spray, then clear coat, and buff to smooth/blend it all out.
Either way, put some paint on those chips on the metal parts. Paint primer is porous so it is susceptible to water getting though and hence, rust.
Old 06-19-2014, 09:34 PM
I would just use a lanka touch up paint system which can be bought from autogeek. It was easier to apply compared with traditional mixing and applying no need for re priming.
Old 06-20-2014, 02:52 PM
FYI, dealer said the primer is gray. Bought touch up paint from dealer, only prob. is that it doesn't bond well. Comes off it u rub on it, it's ok if u dont. Will ck again after it's been on for a while.
Old 08-18-2015, 08:58 AM
Get some liquid (not spray, or spray in a lid) adhesion promoter. Use a THIN needle and put just a touch in the bottom of the hole. Wait 5 minutes and go.
Beading needles can be found at hobby store or Joann's.
Old 10-30-2015, 01:33 AM
Hmm may be the dealer could sell you a touch up paint originally for your car. These may be available in liquid or spray form.
Thread Thread Starter Forum Replies Last Post
Keys with Chips / Alarms / Override options Ricky Ralph DIY - Do It Yourself 1 04-29-2015 12:27 PM
Performace Chips Question mike2009yahoo ECU & Electronics 2 01-11-2010 07:44 PM
WTS:HTC Magic:$320,HTC Touch Pro 2:$300,HTC Touch HD:$260 luzu001 Appearance 0 04-08-2009 01:20 PM
ECU chips Octapulse ECU & Electronics 14 09-06-2008 03:49 AM
YOUR TAKE ON: MOD CHIPS OnE_To_HatE ECU & Electronics 9 02-08-2008 03:26 PM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
