1995 Camry distributor removal
I'm having to remove the distributor in order to replace the ignition coil, which mounts from the bottom and is real hard to get to. The two bolts are off, after I marked the location of the distributor, and I now cannot remove the distributor itself. What can I do to unlink the distributor from the shaft?
There are two bolts (on a metal plate , one is left and the other is underneath the distributor) for the distributor that need to be removed, after its removed you simply slide it out to the right , dont forget to buy a distributor o rings , and if you have oil in the lid you need to replace the internal seal (kbox.ca rebuild kit has one ,(this is not at the dealer))
turboxb9s
06-24-2007 03:26 PM
1995, 2000, 95, 96, camery, camry, coil, disassembly, distributer, distributor, removal, remove, replacing, toyata, toyota
