1995 xle low pressure refrigerant port location
Old 07-29-2015, 11:09 AM
GPSIS's Avatar
Default 1995 xle low pressure refrigerant port location
Hello,
Does anyone have a photo [close up AND expanded view] of the location of the low pressure port used to recharge the freon in a 1995 Toyota Camry XLE?
Apparently the location of the base Camry and the XLE are in different locations.
Regards!
Old 07-29-2015, 05:25 PM
Low pressure is located in the passenger/firewall corner of the engine compartment.
Old 07-30-2015, 09:41 AM
GPSIS's Avatar
Thanks for the speedy reply ToyoMoho!
BTW do you have any photos of the location...I'm not mechanic and this is a first time job for me...something close-up and another from further away would work in order to give me perspective.
Regards!
Old 07-31-2015, 10:43 PM
Find the windshield wiper motor, then look down and find the two A/C metal lines. There should be a gray plastic cap exposed on one line. Remove the cap to expose the fitting.
Old 08-01-2015, 11:26 PM
I recommend using one of those filler cans with pressure gauge. Pop it on there and it is almost idiot proof. If you put it on the wrong line it either won't seal or the pressure will show too high.
johnbats
07-03-2013 04:15 PM
stouto
08-05-2011 01:12 PM
a1parrothead
10-25-2010 11:11 AM
jntskip
05-30-2010 08:29 PM
darjevon
10-12-2006 02:28 AM
Quick Reply: 1995 xle low pressure refrigerant port location
