1996 Camry Idle issue when warm
Old 11-11-2009, 10:56 AM
run53's Avatar
Default 1996 Camry Idle issue when warm
My '96 4 cylinder camry (automatic) idles normally until warmed up fully. Then once fully warmed (15 minutes or so) it will idle extremely high after I accelerate. Basically it will stay at the RPM's that the accelerator last took it to, almost as if it is on cruise control. I have asked a couple of people about these and they suggested a vaccum leak. Others said it is a sticking dashpot (but I don't know where that is on the '96 camry). Is there anything else that may be the problem? Also, if i quickly accelerate the pedal and let off, the idle will return to normal again.
Any help would be great! Thanks!
Old 05-09-2016, 03:52 PM
erixon73's Avatar
Mine had a throttle body gasket leak - replacing that corrected the high RPM issue.
PeteWinter
01-19-2024 10:48 PM
Lorin
02-07-2014 11:25 AM
acsrebel
05-18-2010 04:47 PM
ldballoon4
01-21-2009 06:35 PM
fixitguy63
03-28-2008 07:34 PM
Quick Reply: 1996 Camry Idle issue when warm
