2001 Camry fuse diagram?
Old 05-02-2011, 12:51 PM
diyj98's Avatar
Default 2001 Camry fuse diagram?
I have an 01 V6 Camry. The air has quite working and the air light blinks. I thought it might be the relay, but I don't have an owner's manual to know which relay is for the air conditioning. Can anyone help me out?
Thanks
Old 05-04-2011, 10:04 PM
full house's Avatar
can't you find one in the web? you might find in Camry official website...
Old 05-04-2011, 10:35 PM
There is a long narrow relay box on the drivers side of the engine compartment.
There are 5 relays, the compressor clutch relay is located on the opposite side of the fuses. The AC fuse is also located there.
Check the relay, if not the problem post back.
Old 05-05-2011, 06:59 AM
diyj98's Avatar
No, I couldn't find one on the web, but I did order the relay and luckily it was smaller than the other relays, so I automatically knew which one to replace. The new relay did the trick and it's working fine now!
Old 05-05-2011, 10:55 AM
Great!
camryvasaq
07-10-2012 07:38 PM
BigKeysCPP
11-04-2011 11:01 AM
bruinbrawl
03-14-2011 07:37 AM
bst00
02-27-2007 01:33 PM
Quick Reply: 2001 Camry fuse diagram?
