2012 Camry SE Oil Change - Camry Forums - Toyota Camry Forum
LinkBack Thread Tools Search this Thread
Old 10-08-2012, 07:37 PM
Default 2012 Camry SE Oil Change
Hi All,
I'm new to this forum. I have a new 2012 SE 4cyl. I plan to change my oil before the 10K free service. I haven't been under the car yet but it seems pretty straight forward. Is the oil filter the same one as on the 2011 4 cyl?
I have a variety of cap wrenches. Is a cap wrench OK to use to remove the filter housing or do I need to use the part specific to this housing? Any suggestions would be appreciated. Thanks.
Old 11-11-2012, 09:11 PM
Hello, its the same as the 2011, the filter wrench can be purchase in any parts store, when you purchase the filter, it comes with the drain tube to drain the oil out of the filter housing first,before it make a mess then the rest is just removing the filter, replace the oo-rings using the supplied ones that came with the new flter, I bought my filter from the dealer, its just a better quality, thicker, just remember to used synthetic oil and save your receipts in order to proof you maintained service on you engine
Thread Thread Starter Forum Replies Last Post
Engine oil for a 2012 Camry 3.5 V6 d00dy DIY - Do It Yourself 4 12-24-2014 12:07 PM
Low Oil Pressure after Timing Belt/Oil Seal Change pmaharana New Member Area 5 05-03-2013 11:26 AM
if i change my 4cyl enguine to a v6 wat else will i need to change change jairopion Engine & Internal 1 09-22-2008 10:40 AM
2007 camry first oil change yangt0720 General Tech 6 12-22-2007 08:35 PM
Tags
2011, 2012, camrty, camry, capacity, change, cyl, filter, intervals, location, oil, procedure, se, toyota, wrench
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
