99 Camry LE left rear interior door latch not working
Rear passenger interior door handle will not open the door, but the exterior handle works. When I manually latch the door with it open, the interior handle works, it unlatches the latch. I have put a screw driver with the same diameter as the door strike in the latch to simulate the strike and the interior handle will work unless I push pressure against the latch. I have had the interior door cover off to inspect the mechanism and every thing seems to working properly. Are there springs that loose tension over time?
kiron
06-26-2011 09:45 PM
awbooth
05-23-2010 08:19 PM
