Belt tensioner snapped.. worth replacing?
Old 12-29-2016, 10:55 AM
technut's Avatar
Default Belt tensioner snapped.. worth replacing?
So a friend was switching out the alternator on my 2007 Camry SE (v4) and the tension bolt thing snapped off while putting things back together.. he was able to get the belt back on and tightened from under the car (car was on a lift). At this point it's all together and from what I've read online it seems like replacing the belt tensioner is quite a process. Is it a big deal to just leave it as is? I'm not sure how big of a deal it is being that he was able to do it from under the car. I took a photo..
Old 12-29-2016, 02:24 PM
If this is the tensioner bolt for the alt it should be easy enough to replace.
The tensioner for the other belt is more difficult.
If the alt belt is tensioned OK and two bolts holding the alt to the bracket are tight, it should be fine.
Old 12-29-2016, 10:25 PM
technut's Avatar
Yes it's for the alt belt; that's what I was thinking too. Thank you for the reassurance. I think we'll just leave it and maybe replace it when changing out belt next time
ivan walker
11-22-2012 12:58 AM
lacruiser
08-05-2009 05:07 PM
johnbrisc
03-29-2009 03:34 PM
dmitchell
01-20-2008 08:22 PM
thill2708
04-12-2006 07:48 PM
Quick Reply: Belt tensioner snapped.. worth replacing?
