2009 camry over heating and heat don't work
Old 03-04-2023, 09:56 PM
Josh101680's Avatar
Default 2009 camry over heating and heat don't work
I have a 2009 camry. The heat works as long as the vehicle is in park and it don't over heat, but as soon as you start to drive the vehicle, the heat gets cold and the car starts to over heat. I have replaced the thermostat and water pump. Any help would be appreciated
Old 03-05-2023, 10:03 AM
mdgrant16's Avatar
THe only thing I can think of that would help is to check your coolant level, I know that can affect your heating while driving but If thats not it then I would suggest taking it to a mechanic shop to be checked out.
Old 03-05-2023, 11:58 AM
Engine model, 4 or 6 cylinder?
Old 03-07-2023, 02:00 PM
melvin4503's Avatar
Default Flush radiator with a very good flush out that needs a nebulizer to work
Radiator plugged most likely . Try fluhing it with a very good flush adivative .
Old 06-24-2023, 08:37 AM
What-Ya-Got's Avatar
Any update?
curtarseneau@gmail.com
07-11-2022 04:33 AM
204chucknorris
01-03-2013 07:21 PM
martakmart
03-23-2009 05:42 AM
jshoe
06-12-2008 07:58 AM
chilcko
01-28-2007 09:50 AM
Quick Reply: 2009 camry over heating and heat don't work
