Camry 2010 Throttle Body & PCV Valve
Hey everyone
I'm trying to locate the Throttle Body on my 2010 Camry SE. I couldn't locate a throttle cable under the hood like my old Integra has. This would tell me where the Throttle Body is. The reason I'm looking for it is I'd like to clean it (I know how to clean it). Any advice/drawings/pictures ?
I'm also looking for the location of the PCV Valve. Dealer said I ought to replace it at 40k miles...and I ain't paying them $125 to replace a $10 part. Any advice on this?
Thanks guys
Thanks guys
actually, knowing what engine it is helps either.
anyhow, you do not have cable. it's drive by wire throttle. basically, your gas pedal is nothing more then "I wish" pedal, that tells ECM what you wish to do, then ECM considers as programmed.
air filter air hose should guide you straight to it. on my 07 TCH it's waaaaaay down there below the valve cover, on the air intake. well hidden.
actually, this is 2010 throttle body, with no cable attachment and obvious electrical pintle valve actuator:
2.4L 2.5L 2.7L 3.3L 3.5L Toyota Camry Avalon Highlander Lexus RX Throttle Body | eBay
OK I see the electrical connection here, with no cable attachment like you say. Electrical connection would tell throttle body what position to be in. That helps.
yes, I have same engine in 2007 Camry Hybrid. follow the air duct and it dips down and behind the valve cover. Throttle body is well down there, you almost can not see it at all.
there's quite some number of parts to disconnect before you get to it. honestly, I seriously doubt it's dirty at 40 000 miles. but hey, it's a project! better than booze or drugs.
also car should have electrical assist power steering, when electrical actuator - controlled by computer - assists and corrects with steering wheel movements.
mine also has electrical a/c compressor and 2012 has electrical water pump.
A LOT of components is now ECM controlled.
hardyrxp
03-26-2010 09:28 PM
