1997 Camry Driver's Seat Won't Raise/Lower
Old 08-05-2010, 04:13 PM
MichiganDriver's Avatar
Default 1997 Camry Driver's Seat Won't Raise/Lower
I have a 1997 Camry, as the title says. The driver's seat will not raise or lower when I turn the manual ****. The **** itself it fine, as is the splined shaft.
I took the seat out of the car, and I see that when I turn the ****, the small gear that is supposed to raise the seat does not turn.
Is there a fix other than buying a new seat? If I need a new seat, I welcome your advice on finding one.
Thanks.
Old 08-06-2010, 09:21 AM
Probably a better question: what other model years or other vehicle models have seats that are the same as the 1997 Camry? My search of the auto salvage databases has been pretty narrow. If I knew a range of years or some other models that are compatible, then I think I would improve my chances of a hit significantly.
Thanks in advance.
bobw1008
06-09-2015 07:53 AM
Poppa shine
11-26-2014 03:06 PM
corporateD
07-15-2014 09:04 PM
Wellington
12-22-2011 10:02 AM
khooper
04-18-2008 07:18 PM
Quick Reply: 1997 Camry Driver's Seat Won't Raise/Lower
