Keys with Chips / Alarms / Override options
Old 04-28-2015, 01:18 PM
Ricky Ralph's Avatar
Default Keys with Chips / Alarms / Override options
HI Guys-
I have a 2001 Camry XLE v6 / just got it. Want to get spare keys made but it has a chip / Went to the dealership and Id like to find a way around paying $200 for the computer reset and $40-65 per key.
Currently I have ONE valet key (won't open trunk of Glove box) and a FOB.
Here's the Ultimate best case wish-list scenario. >I have one key that will work in every lock, and a pile of spares - The Chip reader and alarm functions overridden for good > not have to drop a ton of money to do this.
1) can the key chip reader function be overridden so a non-chip-key will work?
2) can I disable the alarm somehow? I hate it - it goes off sporadically. (i surfed the forums but didn't get a solid answer for my model car. )
2.2) Can I cut the alarm horns without interfering with the actual horn or have it trigger the computer to disable the car?
3.) if I cannot override the key chip is there anyone besides the dealer that can duplicate keys and maybe make a key to fit the truck lock?
Thank you in advance for your help.
Old 04-29-2015, 11:27 AM
1) The key chip reader can't be overridden.
2) Check if the car has a window breakage detector that may be set to sensitive.
2.2) The horn may have blue/white and white wires. White is +12v, the blue/white wire goes to computer which grounds it to activate horn. If disconnecting the wires, tape them up to prevent shorts.
3) ? The issue is you don't have a Master key which is required to make another key without outside help. That's why the computer needs resetting/reflashing. Call around to auto locksmith who may be able to also do this. The cost is still going to be around $150.
The type of alarm system depends on if the alarm was factory or dealer installed. Check the remote for a red dot above the lock button.
The Valet key is limited as to what locks it will open. Toyota or a locksmith may be able to make a Master key from the VIN.
mark garrett
10-30-2015 12:33 AM
mike2009yahoo
01-11-2010 06:44 PM
Octapulse
09-06-2008 02:49 AM
OnE_To_HatE
02-08-2008 02:26 PM
Chris Collins
12-19-2006 01:05 AM
Quick Reply: Keys with Chips / Alarms / Override options
