Location of speed sensor in 1998 Camry LE
Old 09-27-2016, 01:46 PM
MMR's Avatar
MMR
MMR is offline
Default Location of speed sensor in 1998 Camry LE
My son's car, a 1998 Camry LE, 4Cyl, has check engine light come on at times. the speedometer does not work once the car is in motion, but after 10 or 20 miles it starts working again on its own. The code points to the speed sensor being bad. I bought a new sensor but unfortunately cannot locate it in the car. I have found many pictures in Google Images but neither I nor my son can locate where it is to replace it.
Can someone kindly point out where it is? A picture would be nice.
I read that there are two speed sensors. The picture of the one that I purchased is attached.
Attached Thumbnails Location of speed sensor in 1998 Camry LE-toyotacamry1998speedsensor.jpg
Old 09-27-2016, 09:06 PM
Look on top of the transmission housing in the area where the axles enter on the sides.
The sensor is rotated by a gear on the pinion.
The plastic top and bolt holding the sensor into the case should be visible.
You may need to swap the old sensor gear to the new sensor.
pincushion
06-25-2013 05:24 PM
tulihk
10-24-2011 09:18 AM
hardyrxp
03-26-2010 09:28 PM
broncobilly
11-02-2009 09:07 PM
axlman
06-16-2007 01:19 AM
Quick Reply: Location of speed sensor in 1998 Camry LE
