Oil pump leak: what seals? (97 2.2 4cyl) - Camry Forums - Toyota Camry Forum
Thread Tools Search this Thread
Old 04-02-2012, 02:34 PM
Default Oil pump leak: what seals? (97 2.2 4cyl)
I replaced the oil pump on my 97 Camry 2.2 4 cyl last year. Heckuva job!! But it worked.
Noticed an oil leak last week. Sure enough, it's seeping out at the rear corner of the oil pump (right above the pan).
I'm thinking I missed a seal while I was in there last year. I'd rather not do this again next year too! I've got a book, but all the photos are with a shiny engine removed from the car, and things look very different on your back through a three-inch gap with grease on your glasses.
Does anyone have a good description or parts breakout for what seals are needed and where they go to ensure this time is the last?
Ed
Old 04-02-2012, 11:35 PM
The site below has a fair parts break out.
Did you replace the formed O-ring between the pump and housing?
Toyota Parts - Toyota-Parts.com
Old 04-03-2012, 08:15 AM
I bought a complete pump-in-housing assembly from AutoZone. So there was already a new(???) o-ring at the pump and a new(??) shaft seal.
It's a minor leak right now, but a major job. So I'm gonna spend some time finding parts at a decent price and repair tips and help. And then take a couple days off work to extend a weekend to do this! Last time, I had to tow the car to a mechanic to break some bolts loose and I sheared off some exhaust bolts. I wonder what adventures await me this time??
Ed
Old 04-03-2012, 10:21 AM
There are only two seals. The drive shaft seal installed at the pump factory and the preformed O-ring seal.
Do you still have the old pump? Many people just replace the drive shaft seal. Both seal and O-ring are available at the Toyota dealer.
Make sure you install both pump gears with the dot on them facing the same direction.
Old 04-03-2012, 05:20 PM
The big seal in the center is the main crankshaft seal, correct?
And there's no other seals behind this?
Since it's weeping at the corner of the main pump housing body (vice at the smaller pump itself), I wondered if it wasn't simply my seal between the pump housing and the block? I'd still have to take everything apart to check that.
Ed
Old 04-03-2012, 08:07 PM
Would be very unusual to have leakage between the pump housing and block.
Might also consider a leaking camshaft seal.
The oil pump drive shaft has only the one seal centered on the shaft.
Given the oil pump seals are under pressure most leaks of these seals would be more then weeping.
Old 04-04-2012, 01:18 AM
Ah - an upper cam shaft seal leaking and running down inside the covers to leak out when it hits the edge of the pump! So I might not have to get that deep after all, eh?
I might could probably loosen the belt tensioner enough to slip the belt off the cam gears and replace those seals, then see if the leak stops -- Yes?? Or pipe dream??
Ed
Old 04-04-2012, 08:00 PM
Yes on removing the belt from the cam pulley at the top.
There is only one seal to replace on the cam. Take note of the small clearance between the frame and the engine. This makes installing the seal more of a challenge as you can't drive it in. You can buy or make a tool that uses the cam bolt to pull the tool and seal in front of it into the head.
Old 04-09-2012, 10:18 AM
Just a crazy thought: has anyone ever tried splitting that bottom timing belt cover so you don't have to remove the crankshaft pulley to get it off? I would love to just notch it, but that would leave a big hole for rocks and dirt and junk.
Thread Thread Starter Forum Replies Last Post
1993 and 2000 Camry Fixing Oil Pump Seal leak (Do I have to remove the oil Strainer?) umdaman DIY - Do It Yourself 4 05-21-2013 10:18 PM
Bad PCV causing Valve Seals to Leak? pederpod Engine & Internal 3 08-02-2011 02:25 PM
Camry 5SFE Timing Belt, Water Pump & Oil Seals Replacement hardlymoving New Member Area 0 07-28-2010 07:28 PM
oil seals cam and front crank twizzerb General Tech 2 06-02-2010 06:00 PM
timing belt and oil seals job twizzerb DIY - Do It Yourself 4 02-06-2010 08:09 PM
Tags
22, 97, 97camary, camry, crankshaft, gasket, housing, leak, leaking, oil, pulley, pump, removal, seal, timming, toyota
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
