P1135 Code 2002 Camry SE V6
Old 08-17-2011, 08:42 PM
francescotedesco's Avatar
Default P1135 Code 2002 Camry SE V6
2002 Camry SE 3.0LV6 P1135 Code Which Air/fuel or oxygen Sensor is it? I have four sensors, 2 upstream and 2 downstream. All have different part numbers. I am guessing Downstream, rear. Can anyone confirm or deny and why?
Old 08-18-2011, 10:47 AM
Bank 1, Sensor 1.
Bank 1 is the rear bank of cylinders closest to the firewall. Sensor 1 is the first sensor on the exhaust system coming off the head.
If replacing the sensor suggest Denso or Toyota brand plus NOT to use a universal type.
These sensors can fail, not uncommon.
Sometimes the fault is to due to something else such as design issues. If so there might be a technical service bulletin (TSB) on this car which may relate to your problem. The dealer would have the info. The car is out of warranty thus even if a problem covered by TSB the dealer will charge you. But suspect the part is bad as any TSB issues would have shown up years ago.
ToddS
11-11-2019 12:56 PM
ToddS
03-26-2012 07:22 PM
SaganGathering
05-29-2009 03:43 PM
kjcho92
03-05-2008 12:32 PM
flyboi
08-15-2007 02:17 PM
Quick Reply: P1135 Code 2002 Camry SE V6
