95 brake light out when headlights on
Brake indicator light on dash is on. All brake lights work when headlights are off.
Driver side brake light off when headlights are on. Have not tried new bulb yet.
Some bulbs do, others don't.
The ground wire is white/black. Check continuity with ground using an ohm meter.
All except the high mounted bulb receive power from the same source. Have someone apply the brake while you check for battery voltage at the green/red wire.
