'96 Camry, RS3000 Alarm issue, Ignition locked... Help!
Old 09-23-2010, 09:17 PM
Richmond71's Avatar
Default '96 Camry, RS3000 Alarm issue, Ignition locked... Help!
Hi,
I have a 1996 Toyota Camry with a factory alarm installed. The model is the RS3000. I had unplugged the alarm years ago and surprisingly today it went off. I don't have the remote control. I couldn't get it to stop, so I unplugged the battery. When I reconnected the battery everything else with the car worked, but the ignition has gone into Starter Disable mode. The engine will not start, since it is locked by the alarm. I've tried everything from unhooking the battery for 30 minutes. I tried pressing down the green reset button on the alarm brain... but nothing.
I'm at my wits end and I need to be at work tomorrow! Anything anyone could tell me would be greatly appreciated.
Old 12-29-2010, 08:10 PM
dgotts's Avatar
Default Have you resolved Camry Start issue?
If you have, can you please post a resolution..
Old 12-30-2010, 06:09 PM
If you have this type of system DON'T disconnect the battery or it cause the alarm to activate if it was not deactivated.
Try this:
Lock all the doors. Insert key in drivers lock and rotate toward rear of car.
Or if the car has remote:
Lock doors and unlock with remote.
K9AMRee8
11-20-2012 09:47 PM
Pantherman
09-12-2012 02:45 AM
barrettteague
02-27-2012 04:47 AM
dgotts
12-31-2010 11:36 AM
catdean
10-05-2009 03:28 PM
Quick Reply: '96 Camry, RS3000 Alarm issue, Ignition locked... Help!
