Airbag and horn not working!
Hello all! Just had the rack and pinion replaced on my'98 Camry with 216K on it. When I got it back the airbag light was on and the horn doesn't work. Airbag light has never come on before except the usual when starting the car and horn had always worked. Did my mechanic disconnect something and forget to put it back together? Any ideas would be greatly appreciated, thanks!
The Fix
now needs a proper diagnostic scanner to clear the fault code or find the cause of the fault
at high risk of deployment of the bag while you are undoing these systems
you are never to remove the steering wheel with the battery connected
a possible cause
some workshops undo the steering wheel to undo the spline nut ... remove the steering wheel and re align the spline re tighten
so the steering wheel faces straight across so the indicators cancel out as you corner
you can break the clock spring in the air bag system
sounds like the battery was not disconnected
or they forgot to reconnect the horn air bag plug
or a fuse
are the indicators other column stalk devices working
if not a fuse
take it back to them
a possible cause
or a fuse
if not a fuse
Check if the cars hazard lights (emergency flashers) work. If so check if the HORN fuse is blown. Its location is in a relay/fuse box inside the engine compartment drivers side. If OK the horn system should have power.
Find out if the mechanic removed the steering wheel. If so, they may have failed to reconnect the horn and steering wheel airbag to the wiring or damaged the wiring. If the airbag is not connected the airbag light will illuminate.
You can find out if the issue is the steering wheel airbag by connecting a code reader to the cars OBDII diagnostic system. With the light on, a trouble code has been set. The code reader will read out this code which will pin point the location of the problem, as in perhaps a steering wheel airbag fault.
Suggest you return to the mechanic and voice your concerns. They can check the trouble codes.
If the airbag light is on, the airbag system is off and will not work if needed.
milowilli
08-16-2017 09:01 PM
Saeed Ahmed
02-06-2013 01:01 PM
mx3man83
07-04-2009 11:24 PM
