Sign in using an external account
| Register | Photos | FAQ | Members | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendors | TSB & Recalls |
LinkBack | Thread Tools | Search this Thread |
The odds of someone else having a remote that operates your car is slim.
Determine if the alarm was dealer installed or aftermarket. If Toyota installed there may be a light on the left side of the steering wheel below the change holder. The dealer installed systems should have a sensitivity adjustment that can be set to prevent false alarms. The system can also be turned off. I do not have the info here, a competent dealer can show you how to do this. There might be a black plastic box under the left side the dash with a ****. If so, the **** would adjust sensitivity. Also look in the glove box or at any papers that came with the car for instructions on the system. These alarms typically have a model number that starts with the letters "VIP", such as the VIP3200 series. The actual number changes between years and model of car. The VIP series is dealer installed and programmable by using proceedures such as turning the key to ign, stepping on brake peddle so many times, etc. I do not know the actual proceedure. The dealer should know this and possible be able to furnish a copy of the instructions. One more thing, if you go to the dealer ask them to show you how to reset the alarm in case of a dead battery or changing out a dead battery. Often either will cause the alarm to set. And find out if the car has an immobilizer (another optional theft system), this disables the ign system to prevent theft but also will do this in the above cases of dead battery. I include this as many a owner have found themselves in a situation of having a dead battery or replaced the battery and now has alarm problems or can not start the car.
__________________
Joey P |
I bought the vehicle used, so I am assuming it is a Toyota alarm system because I was able to make changes per the RS3200 programming guide. I have included a link to the guide if anyone else needs this. I am reluctant to make any changes (e.g. reprogramming the remote controls or clearing the remote controls) for fear of losing the entire functionality. I did set it up to have "passive arming off" (page 9).
There is no light below the coin tray and no black box with a dial. The alarm is only supposed to go off when you disconnect the battery while it is armed. Unarmed, nothing happens. I checked the battery connection and it is clean (I did some maintenance on itabout a year ago). You did make me wonder if a possible loose battery connection was causing the alarm to go off. That does not appear to be the case. I am going to Toyota tomorrow so if I have any more insight I will share that with you. Thanks http://dutch.northwestmr2.com/Toyota/mr2%20spyder/Accessories/Installation%20Instructions/02%20-%20Toyota%20TVIP%20system%20Programming.pdf |
Toyota looked at the car checking the "wiring and operating system". It checked out OK. There were "no draws or shorts found". I had them disarm the alarm.On an '02 Camry this actually requires the Electronic Control Module to be removed and some wiring modifiactions are made. The service manager said that in newer model vehciles they can simply plug in a control unit and program the changes. He only charged me for half an hour so it was not that big of a process.
The engine immobilzer still works as it should. |
Two questions, please: Can a prankster drive around and set off Camry alarms from a distance? And can mice set off alarms?
Ours is going off in the garage. We'd appreciate any insights. |
What year of car, is this a Toyota alarm or aftermarket?
Have not read about pranksters setting off alarms by remote control, does someone else have the panic button. If the alarm has tilt or glass breakage sensors sit too high the alarm can trigger due to slight vibrations.
__________________
Joey P |
Dear Joey P.
Thank you for your insights. We think the alarm was a Toyota model. After reading your comments, we imagine that our alarm may simply be very sensitive to vibrations. Best wishes, Naperville |
| Tags |
| 1999, 2008, alarm, button, camery, camry, car, home, panic, problem, problems, reason, set, start, toyota |
