All electrical is dead - 1999 Camry
Old 05-22-2016, 10:58 PM
Matt Potter's Avatar
Default All electrical is dead - 1999 Camry
I was changing my timing belt and forgot to disconnect the battery when I moved the alternator. I blew the 100 amp alternator fuse. Unfortunatly, I didn't learn from my mistake and when replacing the 100 amp fuse by the battery I touched my wrench between the negative terminal and the bolt on the fuse. It sparked for a few seconds and now may car is "dead." I have no electrical power anywhere. I havn't found a bad fuse yet. I have checked most of the fuses by the battery. I need some guidance on what to check to diaganose this issue.
Thanks,
Matt
Old 05-22-2016, 11:36 PM
I'm thinking my issue is related to this thread. https://www.camryforums.com/forum/en...problem-39768/
When I get back from work tomorrow I'll look for the fusable link between the battery and the alt 100AMP fuse,
Any other ideas?
Old 05-23-2016, 10:50 AM
Check power between 100A ALT fuse and +12v battery. There is a fusible link in the electrical cable between the two.
gregs396
05-10-2015 12:00 PM
edcamry
12-21-2009 11:13 AM
Cosmos75
04-13-2008 10:11 PM
labgvb
04-04-2006 09:01 PM
FishyMan
04-04-2006 08:45 PM
Quick Reply: All electrical is dead - 1999 Camry
