93' AT ECU vs MT ECU
Old 08-16-2006, 10:43 AM
BearChest's Avatar
Default 93' AT ECU vs MT ECU
My auto tranny is on its last leg, and I would perfer to have a manual tranny anyway. I've done some serious work on cars so the swap isn't a big deal, what I'm worried about is if the timing will be screwed up after I put the manual tranny in. Should I get an ECU out of a camry with a manual tranny? Or will it run ok with the AT ECU?
Old 08-18-2006, 03:49 PM
lavalleemike's Avatar
Default RE: 93' AT ECU vs MT ECU
I believe you will need a different ecu because the computer controls the shifts in the auto. So your ecu would be sending shift signals to a manual trasmisson. I would almost think the wiring would be diff on the manual
99champcam
08-15-2007 11:46 AM
caaznkid
07-11-2007 07:47 PM
ExpressTrain
02-20-2007 05:29 AM
sishinthin
05-15-2006 03:33 PM
Quick Reply: 93' AT ECU vs MT ECU
