Driver side window does not work - 98 Camry
Just picked up my '98 Camry LE, and the only thing I could find mechanically wrong with the car is that the driver's side window does not work. The switch can operate all the other windows, but when I push or pull the button for the driver's side front window, I don't even hear a clicking noise or anything.
Where should I start? I'm assuming this is not a motor problem since it would be going very slow...could it be the switch, or a relay?
Thanks
Thanks
RE: Driver side window does not work - 98 Camry
If the other windows work the drivers console is getting power. You will need to investigate, it could be the switch or the motor. Power goes to the motor is through a Red and Green wire. The motor goes up and down by reversing polarity.
mannyfresher22
02-17-2012 03:23 AM
