98 3.0 injector pulse width way too large. Possible causes?
Old 07-17-2008, 06:30 PM
98blackcamry's Avatar
Default 98 3.0 injector pulse width way too large. Possible causes?
What would cause the fuel injector pulse width to be too large to start the car? The plugs get fouled before it can even start. The only DTC is p1410. Thanks
-Rob
Old 07-17-2008, 08:14 PM
Default RE: 98 3.0 injector pulse width way too large. Possible causes?
Sorry can't post due to ongoing website issues.
All plugs are fouled?
Old 07-17-2008, 08:16 PM
The engine may have a mode that increases fuel flow at cold coolant temps.
Might make sure the coolant sensor is OK.
Old 07-17-2008, 08:17 PM
Check that the fuel pressure regulator is not stuck closed. End of fuel rail.
Old 07-17-2008, 08:18 PM
Throttle position sensor bad causing computer to think the throttle is open.
Old 07-17-2008, 08:19 PM
Make sure the fuel pump is NOT running when ign key on but engine NOT cranking.
Fuel pump should only run when the engine is cranking (or engine running of course).
Old 07-17-2008, 08:20 PM
Code may not have been tripped because of engine never running through a test cycle yet.
Quick Reply: 98 3.0 injector pulse width way too large. Possible causes?
