Need 1990 dash wiring diagram
Old 11-04-2010, 07:31 AM
davyvan's Avatar
Default Need 1990 dash wiring diagram
Recently I saw a dash wiring diagram for a 1990 Camry that was a picture of the dash/console that shows the locations of wiring components running through it, but I couldn't print it. Looked like it was from a factory service manual, not Haynes. The lighter, dome light, and antenna don't work, the fuses are good so I think it's a bad ground or loose connection, but would like to see where it is before I take everything apart. Thanx!
Old 11-04-2010, 11:11 AM
This might help you narrow down the issue.
The antenna uses the Gauge, CIG, Dome and Radio fuses.
The Cig and Dome items are on one of these fuses.
If the radio works, the Radio fuse is OK.
If the check engine light comes on with the ign key the Gauge fuse is OK.
If the glove box, ign Key and trunk lights work the Dome fuse is OK.
If the clock works AND keeps the right time the Cig fuse is OK.
Send a Private Message with email and will reply with some wiring info.
Old 11-12-2010, 09:44 AM
davyvan's Avatar
Default Thanks!
The electrical service manual is excellent!
soccman
06-07-2010 10:54 PM
skidrowcustoms
07-28-2009 11:37 AM
y2kwht150
07-26-2009 02:03 PM
bbaker
06-26-2009 12:26 AM
matt
11-04-2007 01:57 AM
Quick Reply: Need 1990 dash wiring diagram
