No. 1 fan relay and Main FR-DEF Relay+94 Camry V6
In the engine compartment in the left fuse box, there appears to be these 2 relays missing No. 1 fan relay and Main FR-DEF Relay, do I need to fill them in or is just meant to be left unfilled? It's a 94 Camry V6, IMZ-FE engine. If so, needed please provide relay desc, part no. if apllicable. Already got the no.1 fan relay and it fit, but the picture for the Main ECU relay seems to be the right amount of pins ((5) but looks as if there horizontal in position rather than being vertical), the closest match i could find is a blower motor relay autozone part no. 36036 and/or 20006 (5pins vertical). Autozone nor the local toyota parts store can verify what the "Main FR-DEF Relay is". Already tried a Rear Defroster relay and theres not enough pins to match or correctly position it. What is this Main FR-DEF relay? if it' s even suppose to go in there? The car was impounded by the shady police or patsy police once, so i really don't know if someone took out some relays at the yard, I think the watchman said someone did take out a few relays?
Thanks in advance,
Thanks in advance,
