rear window won't go down on 2003 Camry LE
I've been trying to find the relays and fuses for my Camry to see if that's why the rear driver's side window won't go down. I pulled the cover off the one by the Driver's knee but the only ones I could see on the fuse lables that might be it were power door1, power door2, door3, door4. I pulled all of those fuses and then started the car to see if I had the right ones but the 3 working windows still go up and down.
Does anyone know where I can find the relay and fuse for the drivers side, rear window?
Thanks.
Thanks.
RE: rear window won't go down on 2003 Camry LE
All windows are on the same fuses. Check each door switch and drivers console switch for operation with each window, if all windows work OK except the window you are asking about the issue is most likely a wiring problem or may be the motor.
i have same problem, but i got it fixed by a friend.
thats' saved about $300
tell me what is the problem? can u hear any sound when u pressing the switch?
like motor noise? or anything else?
I think it might be the motor. The switch from the driver's console won't put it down and the switch on the door itself won't do it either. There is also no noise at all when you try to put it down.
Thanks for the hints.
If you think it is the motor, try putting 12V DC plus and minus to the two motor wires. Keep in mind the motor direction is controlled by changing voltage polarity in the wires.
jjadus
01-06-2011 09:50 AM
