02 Camry SE transmission trouble code P0770
Old 12-28-2011, 09:14 PM
geno02's Avatar
Default 02 Camry SE transmission trouble code P0770
Hi,
I have an 02 Camry SE w/ 118k mi.- it has a 4-speed auto. I was driving home from a friend's house the other night and my Check engine light came on. Right after that the transmission seemed like it lost 4th gear- my engine would rev to 4000 rpms, was hunting for a gear, etc. At that point I got off the freeway and took side streets home- I was able to maintain 50-60 mph but clearly the transmission was malfunctioning and I feared I was due for a costly transmission rebuild. I changed the trans fluid at 60k mi. w/ the correct Toyota ATF.
This morning I plugged my code scanner into the port and pulled a P0770 trouble code- Shift Solenoid E Malfunction. Is this solenoid serviceable when the transmission pan is dropped? I'm a classic car mechanic (rebuild engines, transmissions, rear ends, etc.), and have worked on newer import cars as well (mostly minor items like water pumps, timing belts, p/s racks, etc.), but I'm no Toyota tech. This car is my daily driver and will bite the bullet if I have to get it repaired correctly.
Has anyone else experienced this transmission problem/ part failure too?
Geno
Old 12-29-2011, 12:59 PM
You can access the solenoid with the pan removed.
There are some issues with this code and trans failure (not just a solenoid).
Is this 4 cylinder engine?
Old 12-31-2011, 05:39 PM
geno02's Avatar
My 02 SE has the 2.4l 4-cylinder.
Is this a typical failure? I'm pretty disappointed if it does turn out to be a transmission failure- 118k mi on a trans. that got a fluid change at 60k mi. is pretty pathetic.
Geno
Old 01-01-2012, 12:56 AM
P0770 is common. The issue is if the problem is the solenoid or trans itself.
There are 5 shift solenoids. You want solenoid E also called SL or DSL. See links below.
http://www.toyotapart.com/U240E_U241...T-TC005-04.pdf
http://madstyle1972.com/Repair/05/2011ne09/cip0770.pdf
Old 01-01-2012, 10:52 AM
geno02's Avatar
Joey,
Thanks very much for the Toyota TSB's- I will try and test the solenoid before I make funeral arrangements for my transaxle.
Geno
awbooth
05-30-2021 03:40 PM
notacarperson
09-20-2012 10:49 AM
James67
10-19-2011 04:32 PM
cessna
06-16-2010 11:37 AM
broncobilly
11-04-2009 01:04 PM
Quick Reply: 02 Camry SE transmission trouble code P0770
