2000 Camry 2.2 5-sp - rebuilt engine question (did I get a 3sfe?)
Old 03-08-2012, 01:52 PM
ambradley's Avatar
Default 2000 Camry 2.2 5-sp - rebuilt engine question (did I get a 3sfe?)
I have a 2000 Camry 2.2 5-speed. I destroyed the engine a few weeks ago (broken connecting rod, damaged valves, scored cylinder wall, etc.). I ordered a rebuilt engine from AutoZone. The rebuilder is Marshall. The rebuilt engine's serial number has been removed. The new engine does not have threaded holes for the transmission braces. The bosses are there but they are flat, not drilled.
After speaking with a local used JDM engine importer, I am concerned I received a 3sfe instead of a 5sfe. My questions:
Without the engine serial number, and with the head and oil pan installed, how can I tell if I have a 3sfe or 5sfe? The head is also rebuilt, but may not be the same head that came with the engine originally, however if it is from a 3sfe, that will be very strong evidence.
Did all 1997-2001 USA Camry 5sfe engines have threaded holes for the transmission braces, or was that only certain years, or manual transmission cars?
Are the transmission braces necessary? Anyone running without them for any length of time without negative consequences?
Old 03-08-2012, 10:04 PM
Suggest calling Marshall and asking about the differences. The must know what the have l in order to market the engine to the correct vehicles.
Marshall Engines : Contact Us
Check the stroke, 3SFE = 86 mm, 5SFE = 90.9
Old 02-05-2016, 09:49 AM
rajallen's Avatar
I bought engine for my 99 Camry from Engine World Inc in Houston last year and I am very happy with it
Old 02-28-2016, 07:30 PM
rickkerny's Avatar
I have 2003 Toyota Camry which has a blown engine. Can someone recommend a low mileage engine or rebuilt engine ?
rickkerny's Avatar
Head gasket busted on mine. I see used engines with 100,000 miles are being sold for $1500. Can I get some suggestions here ?
Old 02-28-2016, 07:31 PM
rickkerny's Avatar
I live in Houston and all I see is junk yards here. I feel comfortable buying a rebuilt engine.
dbsanders
03-19-2011 09:54 AM
camrymycar
02-16-2008 05:55 PM
Indolent
01-17-2007 06:19 PM
Indolent
01-17-2007 06:18 PM
Boring_Camry
04-01-2006 09:19 PM
Quick Reply: 2000 Camry 2.2 5-sp - rebuilt engine question (did I get a 3sfe?)
