5 speed
you need a donor car or a half cut has to be a 1 mz 1998 manual gearbox set up
it will have all the things you need to complete the task without making lots of trips or trying to source bits and pieces
sell the unwanted scraps
a quick list of needs
flywheel /clutch /pressure plate
gearbox
master and slave cylinders / CV joints/ manual gearbox mount ?
shift stick/stick cables/ pedal box instrument panel/ center console
radiator
if you have cruze the cruz pedal switch
using the manual engine ecu saves guess work
possibly a manual starter motor ?
gearbox
radiator
atlvalet
07-28-2006 02:02 AM
Keoni90GTS
01-21-2006 01:23 AM
