5 speed
Old 08-27-2016, 10:31 AM
Josephs's Avatar
Default 5 speed
Hey I have a 1mz 98 Camry with an auto trans and I want to swap it to a 5 speed. What trans would be the best trans to get and what all would j have to change out to do it as far as ecu and electrical?
Old 08-29-2016, 01:50 AM
dirty hands's Avatar
you need a donor car or a half cut has to be a 1 mz 1998 manual gearbox set up
it will have all the things you need to complete the task without making lots of trips or trying to source bits and pieces
sell the unwanted scraps
a quick list of needs
flywheel /clutch /pressure plate
gearbox
master and slave cylinders / CV joints/ manual gearbox mount ?
shift stick/stick cables/ pedal box instrument panel/ center console
radiator
if you have cruze the cruz pedal switch
using the manual engine ecu saves guess work
possibly a manual starter motor ?
atlvalet
07-28-2006 02:02 AM
screaminDOHC
07-14-2006 10:25 AM
rturlington
05-27-2006 03:11 PM
07v6
03-27-2006 05:46 AM
Keoni90GTS
01-21-2006 01:23 AM
Quick Reply: 5 speed
