96 Camry...set cam time marks...still won't start - Camry Forums - Toyota Camry Forum
Thread Tools Search this Thread
Old 02-04-2008, 02:38 PM
Default 96 Camry...set cam time marks...still won't start
Any suggestions? I replaced the head gasket on 1996 Camry 2.2... I then followed the Chiltons instructions of aligning the timing marks on both cam gears...and, #1 cyl was closed. Then, aligned timing mark on cam pulley. Rotated to TDC on crank, then installed belt. Made sure rotor pointed to #1 cylinder, rotated 720 degrees, and marks still all line up....engine turns, got spark and fuel, but no ignition....turns over with dull "pop" sound evenly as rotates.
I've rechecked the timing marks about 4 times now...can't figure it out! I stripped two bolts connecting the exhaust pipe to the cat converter, which is directly connected to the exhaust manifold...will a leak like this cause the vehicle from firing??? Pressurized or something bizarre? Having machine shop now pull stripped studs from cat...
Old 02-04-2008, 04:09 PM
Default RE: 96 Camry...set cam time marks...still won't start
OMG! LOL...I had the cams timed not at TDC compression stroke...I was 180 degrees off! I feel like a jackass, all day yesterday trying to figure it out....shulda just sat back relaxed watched the game, and waited until today when my brain was working!!
Old 02-05-2008, 02:11 PM
Not that first one that installed the timing system 180 degrees off, at least it is an easy fix
Thread Thread Starter Forum Replies Last Post
New battery and Alt.. but still won't charge.. Jim2 ECU & Electronics 8 08-22-2013 07:00 PM
V6 four cam 24 1993 LE won't start - help please! Camryfam1993 Engine & Internal 3 08-09-2011 12:21 PM
Aligning cam Marks EarlT General Tech 2 05-24-2011 11:05 PM
Engine cuts from time to time Huo Yuanjia Engine & Internal 2 03-16-2011 04:14 AM
timing marks on intake and exhaust cam shafts ford1 Engine & Internal 4 04-04-2009 12:16 PM
Tags
1996, 96, aligned, cam, camry, camshaft, gears, head, headgasket, marks, pulley, start, timing, toyota, wont
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
