broken thermostat housing stud
all three is bad luck
broken because of corrosion
if the engine block side of that housing for the thermostat cover
can not be removed or purchased
two options
if a bit of the stud is workable
heat up or weld a nut to what is viable
then undo
or loc-tight two nuts to remaining thread to undo carefully
if broken at the base of the stud
drill them out straight ... tap a new thread and helicoil kit
three new studs
two options
then undo
three new studs
