Vin Decoder
or
Login with Facebook
Cruising RPM
Chat about beefing up your engine's insides here.
Cruising RPM
01-16-2017, 01:45 PM
Sacaledus
Cruising RPM
New member and Toyota owner. When cruising down the interstate, O/D on and at 70mph the RPM's are at or just under 3k. Is that normal?
Sacaledus
Send a private message to Sacaledus
Find all posts by Sacaledus
01-16-2017, 02:34 PM
toyomoho
When driving turn the O/D off and determine if the RPM rises. If so O/D it appears to be working.
If the trans shifted through 1, 2, 3 and O/D is working, then the RPM should be normal.
toyomoho
Find all posts by toyomoho
2008 Toyota Camry Hybrid- When does Cruising Range reset?
NWiatrak
06:31 AM
"Cruising Range" calculation on Fuel Consumption on '12 XLE
learn2turn
04:17 PM
Brakes squealing while cruising
adliu
08:01 PM
RPM's Go up and Speed goes down?
axlman
09:19 PM
Tachometer RPM Speed?
kimbee1022
12:24 PM
Replacing Radiator
Posting Quick Reply - Please Wait
Quick Reply:
Cruising RPM
The following errors occurred with your submission
Okay
Quote message in reply?
08:15 AM
