Fuel pressure regulator vs fuel pump
Thanks, Toyomoho, for responding to my post on Oct. 24 concerning intermittent power loss at speed (I was registered under a different name but had failed to enter my full email address and thus was blocked from replying. I've just re-registered.)
Question: How would I isolate whether my problem is a faulty fuel pressure reguator or a faulty fuel pump?
Thanks again.
Thanks again.
loss ofd power and speed
hi guys...av gotta aquestion about my 1996 toyota camrey......sometymes all over sudden it reduces speed even if i press the gas paddle..the speedometre stick will go a little high but the speed will remain the same...then i noticed that now the stick couldnt even move.....some times example if i come like to a stop the car could not pick up well and will go up to like 40mph and i feel like its like somethind holding resisting the movement of rotating parts its like driving a manual car in a wrong gear....plis help
No sure I understand you description.
Does the trans "feel" like it is in a higher gear then it should be?
Sometimes the torque converter can fail to unlock, the car would "feel" as if starting out in a high gear.
Bam Bam 65
10-20-2013 05:54 PM
