How to replace fuel filter for 93 camry - Camry Forums - Toyota Camry Forum
Thread Tools Search this Thread
Old 07-03-2008, 04:19 PM
Default How to replace fuel filter for 93 camry
How do you replace a fuel filter for a 93 toyota camry? I know the location but is it too difficult?
Old 07-03-2008, 06:11 PM
Default RE: How to replace fuel filter for 93 camry
Are you talking about the can filter in the engine compartment?
Not difficult IF the lower tube fitting breaks loose easily. Often owners find it extremely tight making removal difficult or impossible.
Use two wrenches, one on the can fitting. Ideally use a flare wrench on the fuel line fitting. Replace the washer on the top fitting or it can leak.
Unless the engine is showing signs of poor performance the filter never needs changing.
Old 07-07-2008, 03:48 PM
yea the can filter...now do i have to like disconnect the battery or the fuel pump before i change it??
yea the car is running in poor performance
Old 07-07-2008, 10:45 PM
No need to disconnect the battery, etc.
Even with engine off, the fuel line will be under pressure, wrap a rag around the fitting to prevent gas from squirting every where. Do the job when the engine is cold.
Old 07-08-2008, 12:40 PM
Thanks so much mann
Thread Thread Starter Forum Replies Last Post
99 camry fuel filter cjsmith0703 DIY - Do It Yourself 8 04-22-2012 05:03 PM
1998 camry fuel filter problem Ronman DIY - Do It Yourself 1 03-18-2012 11:51 AM
How-To: Replace the Fuel Filter on a '04 Camry therealjab DIY - Do It Yourself 0 07-11-2011 10:59 AM
1997 Timing Belt: To Replace or Not to Replace drickelton Engine & Internal 4 07-11-2008 10:13 PM
2003 camry fuel filter replcement EagerBeaver General Tech 5 01-08-2008 10:28 PM
Tags
07, 1994, 93, 96, camry, change, changing, filter, fuel, gas, line, locate, replace, required, toyota
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
