how to replace transmission mount?
Old 08-13-2007, 09:22 PM
vin888's Avatar
Default how to replace transmission mount?
is it easy to replace the transmission mount of 1998 camry 4cyl automatic?
Old 08-15-2007, 12:08 AM
toyoboy's Avatar
Default RE: how to replace transmission mount?
yes it easy to replace the transmission and engine mount..but that also depands on what kind of tools you have.
Old 08-15-2007, 08:53 AM
vin888's Avatar
if im going to replace the transmission mount.
do i need to remove the torque mount (on top of the timing belt)
and remove the front are rear motor mount and jack up the engine
to remove the transmission mount? if i dont remove the motor mount
i wont be able to jack up the engine right?
im afraid if i jack up the engine wont it damage my transmission?
Old 04-14-2015, 12:33 PM
Jbenrod's Avatar
Can anyone add to the discussion of replacing the tranny mount?
Old 04-15-2015, 01:12 AM
To replace the mount you should place a jack under the engine and tranny, usually a place a piece of 2x4 on the jack to kind of span the distance.
Slowly raise the jack until you see the engine and tranny lift up ever so slightly. Do not go crazy with height! Just enough to take the tension off the mounts, nothing more.
Add jack stands to support the engine/tranny, safety first!
Replace the mount and reverse.
The only really area of concern is lifting up too much on the engine/tranny. You do not want to break any pipes, tubing, electrical wires, etc. Just go slow and easy.
Old 04-15-2015, 05:53 PM
dirty hands's Avatar
yes -its only two bolts - if not--- lifting the motor striaght up or on any angle is sure to split the rubbers in the mount
Old 11-21-2015, 11:37 PM
inchica2009's Avatar
Need help please. on my 2003 Camry 2.4L I have already changed the Dogbone.I still have little vibration when I put it in drive or reverse.
Is my transmission mount bad?I was able to inspect the Dogbone with visual inspection.
Is the transmission mount underneath the air-filter-box? do I have to take the air-filter box off to replace the transmission mount?
kclcpa
07-20-2013 01:33 AM
brianjrealtor
11-17-2012 02:32 PM
LCam
04-27-2010 03:32 AM
zcpro
05-26-2009 12:10 PM
drickelton
07-11-2008 10:13 PM
Quick Reply: how to replace transmission mount?
