My Camry does not run well in high humidity!
Old 12-27-2016, 07:59 PM
mobile1's Avatar
Question My Camry does not run well in high humidity!
My 1998 Camry's 4-cylinder engine does not run well in high humidity.
It sputters and will not accelerate.
It takes a long period of warming before it runs well.
What might be the problem?
Thank you for your help.
Old 12-27-2016, 10:47 PM
dirty hands's Avatar
my thoughts
maf is the part that has the atmospheric /barometric sensors built it
give maf a clean and its plug contacts of corrosion
2017 Wholesale New Mass Air Flow Sensor Meter Maf For Toyota 4runner Tacoma Camry Corolla 1998 2008 From Atuomoto, $34.04 | Dhgate.Com
clean or replace the air filter
if no better
make sure the 02 sensors are ok
Old 12-28-2016, 09:47 AM
mobile1's Avatar
Where is the MAF located?
Old 12-28-2016, 11:55 AM
Does it run poorly after a cold start as in sitting over night?
Does it eventually run well when the engine gets hot. Perhaps then running well until it sits over night?
Old 12-28-2016, 12:09 PM
mobile1's Avatar
It runs poorly after a cold start after sitting over night.
After it warms, up it runs fine.
Old 12-28-2016, 11:01 PM
Moisture could be causing issues.
Check the ignition system coils and high tension wires.
You could use a hair dryer to heat the ign system components, sensors, etc one at a time to simulate a warm engine condition.
Travis Banger
12-28-2016 11:55 AM
NewToyFan
09-26-2008 10:23 AM
EDDIE1231
07-25-2008 11:53 AM
94desertsandmica
04-08-2006 06:21 AM
Quick Reply: My Camry does not run well in high humidity!
