My car needs help
Old 07-06-2015, 12:04 PM
jacaiaz's Avatar
Default My car needs help
hello my name is Joseph and I have a 1997 Toyota Camry.sometimes my car wont start and then I'll Drive it and it will stall when I let go of the gas. I recently changed the spark plugsand it took care of the problem for a few days. now when I go to start my car it will crank but wont turn over.it has started a couple times but then I will drive it and it will start whenever I let go of the gas but now it won't start at all
Old 07-06-2015, 05:18 PM
Check out cleaning the Intake Air Control (IAC) valve. The internet will have posts and video.
Old 07-06-2015, 11:47 PM
How many miles on the car? Did this happen all of a sudden or gradually got worse?
Old 07-09-2015, 01:12 PM
jacaiaz's Avatar
okay so I have already clean the IAC valve. In fact I touched it up yesterday with some carb cleaner, I even took the throttle position sensor off to clean behind it.and yes the problem has gradually been getting worse over time. in the beginning it was very much of a problem and now its getting worse and worse to the point where sometimes my car wont even start for 4 or 5 hours
Old 07-09-2015, 01:13 PM
jacaiaz's Avatar
the check engine light is on and it said there's a malfunction in the throttle position circuit. do you think the problem would be fixed if I bought a new one? And replaced it
Old 07-09-2015, 11:31 PM
What was the actual code that was listed?
Your TPS might be bad...
winny101
04-18-2010 07:29 AM
Jesus Freak
12-29-2008 10:03 AM
Justardnck
08-24-2007 08:45 PM
Quick Reply: My car needs help
