who's v6 timing belt has failed?
wondering if the vavles will touch? or is there clearance as in the honda's?
reason is, i was going to change mine on my 95 v6, just passed 90,000 miles (yes i know i put it off).
but for the life of me i could not remove the damper bolt. the belt looked fine (i now you cant really tell by looking), so i just changed all theaccs. belts, rad hoses and buttoned it back up. hope to just wait till it failes if no damage will accur.
curious since i just bought a used nissan truck with 140,000 miles that had the original belt. i did change it asap, but i lasted so long, and was half the width of the toyota belt.
anyones actualy failed? ive never heard ofa toyota beltfail, unlike hondas left and right.
thanks
thanks
RE: who's v6 timing belt has failed?
When you say damper bolt, are you talking about the crank pulley bolt? If so, I posted how I did it last week in another forum.
https://www.camryforums.com/m_17918/tm.htm
If you have the imzfe motor, rumor is that the valves will not touch.
Scot
Scot
ORIGINAL: rscarawa
Scot
Scot
tried all your methods and some others(i also have a 1000lbs 3/4 impact), but bent all my holders.
just trying to find out positivelyif imzfe's are clearanced.
